the first one is at 15psi on 94 pump. the second graph is on about 105 oct mix of race/pump gas at 18psi. It was still really rich but when we tried for more power my clutch said no. as you can see as it hit 444rwtq on pull #20 when it went up in smoke.
I went to the track later on in the night and ran at 15psi. The track was just repaved and the track was very 'green' I would spin through 1st and a most of 2nd then go snakey through 3rd and 4th. When I turned the boost up more I got traction because my clutch was slipping like crazy. Best run at 15 psi, first graph, was:
60' 2.373
330 6.146
1/8 8.942
mph 88.41
1000 11.274
1/4 13.227
mph 113.99
Car weighed in at 3450 with me in it after I removed the passenger seat.
86.5 7mgte/r154
57 trim ct-26, BIC ddp, test pipe, greddy sp, k&n fipk, profec b1, yonaka intercooler with custom BIC hard pipes, lex/550, walbro, safcII, centerforce df clutch (2.5 years old), stock motor other then greddy 1.5mm hg with stock head bolts torqued down to 60ft.lbs . 4.3 lsd, type s bov, thats about all i can think of now.
I drove 400 km to the dyno and track, did 20 dyno pulls, 5 drag passes and drove home. It only took 1/2 a tank of gas for me to go 400km on the highway home btw.
60' 2.373
330 6.146
1/8 8.942
mph 88.41
1000 11.274
1/4 13.227
mph 113.99
86.5 7mgte/r154
