grr with the 1 sided view.
Will 4 inch net you a gain. YES. The question is where in the powerband did you LOSE power
Everyone always always looks at peak numbers. Peak numbers are WORTHLESS. You need to look at overall under the curve power. 4inch will net you higher peak numbers at the expense of the low end. Unless there is a REASON (Ie GT42 or T88 turbo on up) there should be no need to even consider a 4 inch on your setup. 3 inch with a max of 3.5 inch.
also of note.
4 inch exhaust
will be LOUD. Louder than even the Blitz NUR exhaust and that is freaking loud!
