3L 1JZ
Darkcyde
Workin' Man
La Villa Strangiato
s383mmber1 said:
1jz head + 2jz block = 3.0 1jz
I thought we all knew this?
from wiki..
"The 3rd Gen 1JZ came as either a 3L single turbo flat 6 or the 2.5 twin turbo with reworked head incorporating toyota's new VVT-i (variable valve timing with intelligence). Output stayed the same except throttle response was increased slightly as well as TQ figures. This engine was used primarily in Toyota's X chassis cars (Chaser, Mark II, Cresta, Verossa) and in the late year Soarers, as the JZA70 Supra was long discontinued by this time."
1jz 3 liter flat 6?:3d_frown:
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
BlackMKIII said:
Oh noes. Now it'll never be right. LOL.
:madfawk: lol
Psh. I just highlighted the bad info and hit delete, clearly the OP should have just not put the bad info in to begin with lol
Edited it again, also came on 3SGTE.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
You guys are aware the wiki is a site where any Joe Blow can add an article. Don't believe everything that you read on there.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
wikipedia is garbage. do not rely on it for useful information
in college if you use it as a source you are fucked. unless your teacher is an idiot and/or doesnt care
