Billybob9187;2080777 said:
I would love if you were able to make a glove box gauge pod like the one for Subaru. It has cut away slots for boost controllers and other like devices.
ex.
https://www.summitracing.com/parts/atm-20032
Zrain25;2080785 said:
Good ideas. My pricing on that kind of piece, however, would probably be double that Subaru example. Those sort of larger molded plastic pieces are cake when you're making a few thousand of them, but quite expensive in small batches. Maybe I could do some carbon work and make it economical/sexy.
One thing I don't like about those though, is that you then have to drive with the glove box open and look down and way over to your right to view anything, or you keep it closed and never really see the gauges or interact with the units.
I'm thinking my Ash Tray Boost Controller approach will have to be very modular. I should be able to create a system where you could swap out just the "faceplate" and accommodate a variety of parts. IE Different controllers, displays, maybe 52mm gauges...
Also, I've used the voltmeter for a bit now and it's awesome. I love it. Perfect mounting location, IMO. It's out of the way most the time, blocked by the steering wheel, but when you want to check it, it's just a slight nod of the head to view it. It's also interesting to see how the voltage changes at different RPMs and with accessories on or off. Another prototype of the voltmeter is one it's way, hopefully with better fitment around the factory trim. My first one works, but I can do better.
Look for pricing around $60.
