2T & 3T engine questions
te72
Classifieds Moderator
6,610
7
WHYoming
18R-G. Look into it man... was used a lot for Celica race cars back in the day. I think there was even a turbo version at some point. Good for the under 2.0 requirement. :)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
MDCmotorsports;1702462 said:
OHC or DOHC is.limited to 1998cc
you choud make franko 22re might get ya down to 20 liters but I am not fully sure
get 89 plus 22re block and repalce the rods with a 81 rod's and run 20 r head to keep the comp ratio
since the 81 rods are shorter
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Guys, I was trying to do something on a budget, at least on paper.
The direction the posts are going now.... I would just put a B18 in the car. Parts are every where, its cheap, and the little B18 will spin to 10,000 rpm.
te72
6,610
7
WHYoming
18R I'm not so sure would be easy to find, but I doubt they'd cost too much. MDC, did I miss what sort of car this was going into, or is that a secret for now?
MDCmotorsports
Indy 500
Open wheel Midget. The big boys have $40,000 NA four bangers making around 390hp crank.
Great for big tracks, but the two short pavement ovals around here it useless.
So if we can.make 300 hp or 350 hp on a budget, so be it.
SupraMario
I think it was the google
The Farm
I've got a 2tc I'm about to pull out of my rolla and turn it into a coffee table. There is a forum called 3tc.net I think google search should get you there. Gl with the build I'm going 4age in mine.
