I would like to know how much harder would it be to swap the 2jz in the 87 chassis of the supra and would be needed and yes I've done my research and looked through the forums but most that I've found the swaps were done in the post 89 - 92 supras because its a little bit easier with the mount brackets will let the engine bolt right up to them when buying the specific mounts needed thank you much appreciate the help
