2JZGTE Physical dimensions
suicide kp61
OMFG Im a NOOB!!!
Dec 23, 2009
75
wv
I have searched the web and cannot find the actual physical dimensions of a 2JZGTE. My 2JZGTE for my KP61 Starlet build isnt in yet(expect a big build thread) and Im trying to do a little firewall clearancing and core support modification to order a custom radiator. I need a few measurements to see what Im dealing with to lighten the load of work when the motor does arrive.
I need to know the length of the engine from bellhousing mating surface to crank pulley
Length of the valve cover
Length from bellhousing mating surface to the center of the motor mount bolt
Thanks again for any help
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
I thought about doing a 7m in my starlet. not sure on a 2j but the 7m timing cover to back of valve cover was the same length as rad support to the firewall lol needless to say i decided aginst it lol. but good luck.
suicide kp61
OMFG Im a NOOB!!!
Dec 23, 2009
75
wv
Thanks for all the offers,yes I will take both 1j and 2j dimensions. As for the valve cover being the same length as the firewall to core support....LOL Looks like I will be definitely clearancing the firewall. Oh well it will just help the weight distribution LOL
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
Yeah. what rear-end you planning to use for yours?
suicide kp61
OMFG Im a NOOB!!!
Dec 23, 2009
75
wv
Narrowed ford 8.8 with rear disc....Larger than the front LOL I gotta upgrade those jewels first thing.
suicide kp61
OMFG Im a NOOB!!!
Dec 23, 2009
75
wv
Ok so I called the importer and had them measure a motor they had sitting there. It seems from bellhousing mating surface to crank pulley is about 27 inches. Then from the bellhousing mating surface tot eh center hole of the motor mount is about 13 inches. Can anybody who isnt a busy importer rushing to get me off the phone confirm this LOL
