2jzge TPS with 7m ecu
In the middle of a 2jzge swap into my 92, running the 7m wiring and ecu. Will the 2jzge TPS work with the 7m? I looked at the wiring and it shows the 2jz tps to have a vta2 instead of an idle switch. so that means 2 potentiometers in the tps instead of one and a switch
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
No it will not work, I measured the resistance values and they are off, I also believe the voltages will be wrong for the ecu.
You can try but i'm sure it will not work.
Was trying to do the opposite. Use a 7m TPS on a 2jz ECU.
