3p141592654;1848261 said:You are calculating the difference between two temperatures, not the actual value.
Let me give you a simple example, if there is no temperature difference measured, i.e. 0C, then what value would you expect it to be in Fahrenheit? Use you calculator and see what you get, then ask yourself if it makes sense.
I see your logic, and it now makes sense. Thanks!
Basically if my car runs at 87*c at idle and 93*c at highway cruising, I'm seeing a delta (change) of 6*c. Wich is only 10*f not 42*f
Again, Thank you.
