Your welcome. After completing the first 2jz swap and already 1/3 into a 1.5jz swap, I feel like I know enough to be helpful. : p
hottscennessey;1693627 said:The 7MGTE ECU will not run a 2JZGE VVTI (IS300) without running the proper crank trigger. Of course it would require tuning, and you'd lose VVT-i control.
Top = 1jzgte/2jzgte/2jzge non-vvti (in some years)
Bottom = 2JZGE VVTI
Of course this also means a 2jzgte/1jzgte could easily be run off the 7mgte ECU, even without the 7M CPS since the JZ trigger is 12 teeth (where 7M is 24 - NE) and they still have G1/G2 sensors, which would require no modification. the only thing I can figure out is why anyone would want to do it....
Nghty89;1693668 said:You're EFFING kidding me?!? I always wondered if it was at least possible to run the 7mgte ecu off of the 1jzgte crank sensor.... PM me if you have ANY info on this before I sell my entire 7M setup. It would save me $$$$ on my current build. lol
hottscennessey;1694012 said:It's all theory of course, just like the 2JZGE off 7M electronics was, but it makes a lot of sense if you look at all the necessary inputs for the 7MGTE. Also means you could run the 7MGTE off 1JZ electronics.
erags1092;1772231 said:What parts are need for the actual turbo part of the NA-T builds. do most of you just buy kits off of ebay or drifmotion. or buy everything indivually. From what i can gather what you need is.. the turbo, manifold, oil feed/drain lines, blowoff valve, and wastegate. And other parts like boost controller, fuel pressure regulator, turbo timer, and intercooler/piping are they needed or are they just for extra power.
turbo87targa;1833451 said:Old thread bump....Been lookin through the threads and can't seem to find the answer I need...
Which mechanical fan do I need for a pre89 2jzge-T with a PWR radiator?
