So this thread is mainly for me, I've been bookmarking alot of stuff at "work" :biglaugh: and keep forgetting to transfer them so I can reference at home. I'm doing a 2jzge-T w/7M electronics (link to build thread is in my sig) and have a compiled a decent list of posts related to this swap. If anyone else has anything to add, please do so!
Stuff you need:
-2jzge (duh), preferably w/all accessories
-1jz bellhousing if you're using a R154, 2jz W58 bellhousing if you are using a W58 trans
-1jz flywheel or a lightweight FW like DM and 935 sell
-Jza70 motor mounts (late '89+) or BIC swap mounts ('86-early'89 and late'89-'92)
-7M harness/ECU, sensors, injectors etc.
Build Threads etc.:
Yankiwi
p5150
p5150,reasons for going 2jzge-T
hottscennessey
supra87t/t4 and 88supraTT towards the end :biglaugh:
XofXtimeX
Costs in 2jzge-T vs 7M
Headgaskets and C/R
Wiring:
General wiring info
General wiring info2
General wiring info3
Wire routing
CPS info
CPS modification to fit 2jzge head
2j TPS into 7M harness wiring
Alternator
Alternator Wiring
Thread-in o2 sensor
Lines/Hoses:
Radiator
Heater
Heater2
Yankiwi Rad/Heater
P/S hookups, for 1jz but should be similar
P/S hookup pics, for 1jz but should be similar
P/S
Turbo oil lines
My oil feed
CNA-T oil line thread
Oil pressure sender line
Fuel Lines
Misc:
Temp sensors, A/C bracket etc
Mounting
A/C
Throttle Cable
Replacing plugs on a 2jzge
Plug gap
Plugs/gapping
hottscennessey's Stinger map
Basic NA-T installation
GE vs GTE basics
2jzge vacuum diagram
Fitting Domestic Injectors in the 2jzge fuel rail
2jz NA-T 1/4 mile and Dyno #s
Stuff you need:
Build Threads etc.:
Yankiwi
p5150
hottscennessey
XofXtimeX
Headgaskets and C/R
Wiring:
General wiring info
Wire routing
CPS info
Alternator
Alternator Wiring
Thread-in o2 sensor
Lines/Hoses:
Radiator
Heater
Heater2
Yankiwi Rad/Heater
P/S
Turbo oil lines
My oil feed
Fuel Lines
Misc:
Mounting
A/C
Throttle Cable
Plug gap
Plugs/gapping
GE vs GTE basics
