ive had this car for awhile and got it stock! so i started off like most people and had my 7m rebuilt..after about 31 miles i parted everything out to go 2jz! ive never been happier! as for the setup im using my 7mgte electronics and a map-ecu(for now),t4 .68 6262 turbo,arp head studs with a TT head gasket,stage 3 clutch,aem wide band,etc etc heres a few pics of the process! im 90% done im just waiting on my turbo manifold to come in and i need to buy spark plugs which im still undecided with what i would like to run!
after pulling the 7m and removing the bellhousing
working on my harness/wiring the map-ecu in
almost done!
traded my a-tech wheels for these (=
ordered some cool stuff from driftmotion
pulled off the front sump -_-
replaced my front seal while i was at it
head removed and at the machine shop so the block witht he arp's on the stand with my bellhousing on my tranny!
rear sump!
engine off the stand,flywheel installed!
tranny on!
head fresh from the machine shop
shortblock installed!
the 2jz pic
hood off
turbo and injectors in!
head on!
cams in
almost done!
started finishing the wiring!
90% done!
and thats basicly how she sits untill my manifold comes in! ill update more asap!
almost done!
rear sump!
tranny on!
the 2jz pic
hood off
head on!
cams in
almost done!
90% done!
