ok, so i have a 86.5 supra has the typical 7mge rodknock. so i decided to swap a (bonestock)2jzge in, I am going the NA-T route. what do i need for internals, to run around 30 psi
toyotanos;1669955 said:We need information from you, good sir!
1- How much money do you have to spend
**Need For Us To Help You.
2- How much power do you want to have in the end
**Need To Know To Select Turbo. Usually With 30PSI, Ball Bearing Is Preferred.
3- How much work are you able to do (has to be top-notch quality work, not backyard stuff)
**Need To Know.
4- How long are you able to wait for this to come to fruition?
**Important If It Is Your Daily Driver
Reply with info and we shall see what the general consensus is. Until all of that info is public we can't tell you what to do. (more will be needed as well, that is just barebones basics)
hvyman;1670008 said:I vote gt42 with stock fuel. It will be awesome.
