I was looking at some way to get an inxpensive 2jzge (w58/55) flywheel and noticed that the Toyota line of trucks have a flywheel that closely resembles the 2jzge flywheel. It has 8 mounting holes (look the same pattern) and is the same diameter and it looks like the pressure plate mounting stud and holes are the same. The number of teeth is 120 which is different than the JZ flywheel but I figure swapping the starter gear should solve that. They are readily available at local autoparts stores for under half of what I was finding used 2jzge flywheels for. The only thing I don't know for sure is if their deck height matches. This might be something some of you might want to look into. If you find any info on it please post back here as I think it would be great to have a cheaper alternative.
2jzge
Truck
-Tim
2jzge
Truck
-Tim
