2jz/W58 vs. 7m/W58 Is there a difference?
Tura_1JZ
Supra down the block
Aug 26, 2009
114
miami
I searched this but no cigar, I was wondering if there was a difference between the 2 trannys, I have auto 1jzgte 88 supra and Im planning on doing a manual conversion. Its becoming hard to find a r-154 so I was thinking bout droping in a W58. Is one stronger than the other or are they the same?
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
gaboonviper85;1397684 said:
They are the same just different bellhousings...
Both suck in heavy cars!
could you elaborate please?
why does the W58 suck in heavy cars? the SC300 had it stock. (mind you, it was the stronger version of the W58)
gaboonviper85
3,236
Northeast Philly
WTF are you talking about? "stronger version"
the sc300 is a 2jzge....which is why it came with the w58....same with the mk4 na's sport the w58....as well as mkiii.....
All the turbo cars had r-154 or getrag 6spd.
Stronger version....please....the sc300 was no power house and my na mkiii will smoke an auto sc300!
Tura_1JZ
Aug 26, 2009
114
miami
Im running a gt35r single on my 1jz, I don't usaully floor my car Im more of a cruiser. My question is if I drop in a W58 will it last?
gaboonviper85
3,236
Northeast Philly
Last....that's a matter of personal opinion.
It may get you threw a season, a week, 15 min, or for years...it's really hard to say.
Its just not the best idea.
R-154 isn't hard to find...just more expensive.
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
Agreed.....there are a couple on Ebay right now.
Sinful7m
addicted to boost...
Aug 26, 2009
113
Oldbridge Nj
r-154 is stronger and will last longer obviously it had to deal with more stress in turbocharged cars save for a 154 it will be well worth it in the long run
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
the W58 was changed in '89, internally it was changed from an aluminum sandwich plate to a steel sandwich plate, which made it SLIGHTLY stronger than the older (pre '89) W58s.
when i said "stronger version" i was being specific in terms of an updated W58. not upgrading to an R154/V160/V161
