2jz swap... and tranny questions
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
RazoE said:
what about a 2jz-ge using an MKIII w58?
i know it's slightly different from an SC300/NA MKIV, but would the internals be swappable..?
good luck holding the power. If you go turbo it will explode.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
mrsuprafreak said:
I have a 2jzgte with a 2jzge flywheel and a r154 with 1jz bell housing.
You could have told everyone that it won't just bolt up though . .. would have saved some moderate panic. But thank you very much cuz your info still saved me $350 on a fidenza or $200 on a new stock. I got the flywheel off a friend for $20, resurfaced for $40, and the redrilling should not be much more.
For everyone's info the only thing that bolts up is the dowel pins. The flywheel has to be redrilled to suit the 7M clutch bolt holes.
BTW now would be a great time to tell me what else needs modifying while I still have the motor/tranny out of the car.
Cheers
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
Also, found out that the 2JZGE flywheel is thinner than the 1JZ. I can imagine this affects junk with slave cylinder rod. Anything else
mrsuprafreak, I'd really like to know what custom setup your running. Let us know K
kysupra
I'm Single
Apr 25, 2005
72
Lexington, KY
im running the 2JZ-GE fly wheel also. other then having to have it redrilled for the pressure plate i cant think of anything else.
my setup is
2JZ-GTE motor
2JZ-GE flywheel
1JZ Bellhousing
R154
7M-GTE 6 puck ACT clutch and pressure plate
stock drive shaft (lil tight but it works)
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
Thanks Mike, I dug up some old threads but they seemed negative and mrsuprafreak didn't respond to my PM. I was starting to get concerned that further modification was necessary.
I am actually gonna sell the 2J flywheel and brand spankin new spec stage 3 clutch. The day the flywheel was dropped off to be drilled, I found and bought the clutch that I had been looking for all along. It's a twin disc :cool: Just gotta wait 5 more posts until I can do a 4 sale thread :rolleyes:
Again thank you much.
-Jago
mrsuprafreak
Where does it end?
Aug 14, 2005
267
Orlando
-Jago
Sorry for not responding but I was in the hospital for a week with my wife having a baby.
tissimo
Stock is boring :(
Melbourne, FL
congrats!
I'm interested in the 2jzge flywheel? so you have to redrill it for the 7m clutch?
I've always wondered about a 2jzgte flywheel with a 2jzgte PP and a custom Disc (with r154 spline count) anyone know if it'd be possible? would open up a lot of options for clutches on jz swapped cars.. (and seeing how single discs have no problems with 600+whp in mkivs)
mrsuprafreak
Where does it end?
Aug 14, 2005
267
Orlando
tissimo said:
congrats!
Thank you!
Let me see if i can get you some pics of it and i will pm you about it and post more on it
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
Congrats bro! Boy or Girl? Name? Pic would be cool too .. . may be not in this thread though :D
tissimo, yeah from all input given just drill and tap 6 new holes for the 7M clutch. Like I said, I am going to sell the one I am having redrilled. It's been resurfaced once. $100 + ship if you like
Cheers
tissimo
Stock is boring :(
Melbourne, FL
Cheers
haha I'll let you know.. I need a clutch&FW for my 1.5jz.. but current plans are to use my 2j cars clutch and FW and buy a tripple carbon for the 2j (going 71+ when I do go single) so it has the FW too.. just ahve to sell my 87 to afford the clutch!
