2jz single manifolds for mk3 swap
Turbo Drifter
534
Surrey, BC Canada
86_sports_1jz;1133736 said:
yea i know but just trying to help give him an idea that the drewgo manifold may not fit with a bigger turbo. plus its a old pic that i took when i was testing everything out so get over it.
Wow attitude!! I was pointing out to you that he was looking for 2jz single manifolds in the MKIII. I was not sure if you missed it or assumed diffrent, sorry about that.
BTW who is the one being the E-thug on here?
if you saw me in real life i know you wouldn't say anything like that but since we are on a forum you are talking alot.
You also said nothing about this being a temp set up in your first post. It looked unsafe and performance robbing so chill out.
Jeremy
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
sorry i misunderstood you but i hate it when people jump to conclusions without knowning what happened
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
becauseican;1134187 said:
I guess we can include 1jz manifolds here to, I have tried this "ebay manifold" and it doesnt fit well in the mk3 Supra, the wastegate runners hit the frame and it needs to be heated up and flattened to even bolt it onto the car:
fits just as bad as the ebay 2jz manifold then ;)
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
have a similar manifold, albit no drewgo but identical design.
Fits good but VERY VERY hard to get oil return away form manifold since it sits a little far back. Also my pt67 with the big H compressor 3" cover barely makes the bend to clear the manifold.
becauseican
Vancouver
www.bicperformance.com
I just fit a XSpower 2j manifold on a car in the shop, it has the straight t4 flange (not angled), the manifold/turbo fits but the wastegate pipe has to be cut and re welded. Have any of you guys using the Drewgo manifolds had issues with boost creep?. I have some Drewgo 1J manis comming in next week and I will post my results once installed.
Gritz
155
nc
I have that manifold on my 260z, it fits on the 1jz pretty good, i did have to modify the wastegate by cutting, bending out alittle then reweld..very good quality peice though..321 stainless....so far....:naughty:
