2jz overheating
barry
Quebec
My 86 with 2jz single is overheating not to red line about 3/4 Motor runs good and pulls hard .It has dual elec. fans and alum. rad. all 1 yr. old and it being only 2 celcius has me worried.The heater seems to cool it better than the rad..Could the 4'' innercooler be blocking too much air flow?..Thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The intercooler is unlikely - I've got one of those too, and I drive in warmer weather without problems.
It's possible there is junk accumulated between the AC condenser and the radiator. Undo the radiator mounts on the top, push the radiator back, and inspect down the crack for blockage.
Failing that, I'd check the fans - are they actually running? How are they wired, and what tells them to turn on and off? What temperatures are they set for, and how is the temp sensor set up?
Nick 95 6sp
Ported & Polished
Sep 5, 2007
155
S.E. PA
Accumulated junk can definitely make a big difference. Also, I never had electric fans, but at least on the MkIV chassis with 2JZGTE there are very few electric fans that can push as much air as the stock fan. Also, once you are rolling over about 20 mph, the fan is of little or no use to help cooling; fans help cooling when you are rolling slowly or stopped.
If your new radiator is not properly ducted, you are probably getting worse cooling than the stock setup. If you have a decent intercooler it's probably not a major factor although a poor design will be more restrictive of air flowing through it to the radiator.
This oil temp problem may not relate to your issue, but in my experience a 2JZ well into sustained boost will rapidly elevate oil temps to dangerously high levels. For an occasional highway pull you can get by, but for something like prolonged hard driving (like roadcourse track days) IMO you must have a large oil cooler.
I just ducted the air coming in through my front bumper so it can't flow around the sides, it has to pass through the FMIC and to the radiator. I am now also grabbing air from under the stock bumper where I have a narrow wide opening in my front lip and channeling that back to the radiator. This made a significant reduction in my water and oil temps.
