2JZ lower timing gear cover on a 1JZ? Will it fit
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I know the 2J block is about 1/2" taller, but I also know that the upper timing cover from the 2J will fit a 1J if you trim off 1/2" off the bottom. I'm thinking it will fit, but I just need confirmation (mainly for the bolt pattern since I can trim it if it's too tall).
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Ok, so I just now realized that I replaced the lower timing cover this year with a brand new 2J cover and had to trim the top half about 1/2" to get it to fit. So that's the answer, it will fit if you trim the top of the cover :)
