2JZ into MA70 Swap Pics etc
Dr Tweak
Some parts that needed touching up...
Timing belt job done (was waiting on a part that was backordered)
Wiring
Customized oil return lines and engine mount bracket
A/c lines installed
Pulley's installed
Dr Tweak
Lightweight flywheel and ARP bolts
Competition clutch stage 4
Transmission installed
Ready to go in
Chris watching firewall clearance
He told me to look like I was grimacing, LOL
Pulled the engine back out once we knew exactly where to make firewall "adjustments"
Engine bolted in
Left to do... build the exhaust, install the intercooler and cut/route all of the intercooler piping, intake, make a fuel line, install a/c lines and p/s lines, replace the fuel pump, install the driveshaft, install the slave cylinder, heater hoses, route and plug in the wiring harness, install radiator and fan, throttle cable, etc.
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
This swap is comin' along nicely ! When i banger my firewall, i taped a rag to the sledge hammer to make softer punches. However I banged it a lil' too much and craked the evaporator housing which is what's on the other side the firewall. Upside is that I can now fit my hand all the way back there !
I had ran into some tranny crossmember alignement problems, which wasn't solved by just flipping the crossmember around.
steve_mk3
middletown, NJ
Quick question-
Did you retain the JDM components? Turbos, injectors, cams?
Thanks
Steve
BTW - great thread, any additional pics of the firewall adjustment would be appreciated
Dr Tweak
P/S Lines
Alternator wiring and securing the harness
Heater hoses
How to install the radiator fan, hydraulic clutch, pulley, shroud, and radiator
High-density Garrett intercooler
Mocking up the intercooler piping and cold air intake
Custom downpipe welded up and installed
Engine as it sits now.
Swap is done, but it's not starting. Looks like we have the wrong ECU. Anyone have a 2JZ Aristo ECU they could sell?
tissimo
Stock is boring :(
Melbourne, FL
Poodles;1463265 said:
Interesting, always been told the 2J wouldn't fit with a fan shroud. How's the clearance?
Who said that. Its essentiall the same diamentions as the 1j and that works with a fan fine.
Dr Tweak
I logged 75 hours on that project, our shop rate is $75/hour so he technically "should" have paid over $5k just in labor, obviously we can't charge that in real life (which is why we charge a flat rate on swaps instead of by the hour). So to answer your question, $2500 - $3500 depending on various options.
-Doc
