Looking to buy a top feed rail for the 2j vvti,but all I see on ebay are ones that day. Not for use with vvti or Will not for vvti head models...is this just a myth? Or does it work with very little modification? Any help appreciated. Thanks.
I grabbed a non-vvti one and it works just fine. Mind you, you'll have to get the intake manifold injector adapters for whatever size injectors (11mm/14mm) you have. Admittedly, I am using a USDM upper intake and throttle body, so there may be a difference if you're staying all OEM.
