Is the oil pan from a 2JZ-GTE the same as the one from a 1JZ-GTE? Are they compatable? Will I be able to use a 2JZ-GTE oil pan on my 1JZ-GTE? Size difference? Any cross member clearance issues? Thanks.
He is right....just in case you needed a 2nd opinionwerewolves182 said:Yes, it will work without any issues at all. They are identical.
suprastanger507mgte said:He is right....just in case you needed a 2nd opinion![]()
rakkasan said:Well, as long as it's a mid sump I'll agree. The front sumps from the aristos will fit the motor, but not MKIII's...
Technicalities....:icon_bigg
Ric said:It's the same. You can use a 2JZGE lower, you can usually get those cheaper.
