2j oil pans?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
garagefujimoto;907159 said:
Huh? There is no "other" Supra. If it's a Supra, the pan is in the rear LOL. Don't matter if it's JDM, USDM or MadagascarDM
lol:biglaugh:
Okay :
Any 2JZgte pans will be the same / mid rear sump.
Any 1JZ gte ( jza70) will be rear sump.
Any sc300 2jzge pan will be rear sump as well (I have used this on a 2jzgte and its a direct fit. You will need to drill holes for oil return on a turbo)
Any Aristo 2JZgte pans will be front sump. The link I posted will show the difference in the pans . You can use the rear/mid
sump on the supra fromthe GE motor. ( Supra or Sc300 ones)
Look at this link and look at post # 121
http://www.supramania.com/forums/showthread.php?t=50170&page=13
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
hottscennessey;931040 said:
I have a SC300 oil pan in my MKIII, no fitment issues, I suppose it's the rear sump. I never even knew there was a mid sump.
thats why i wanted to post it Lol
oh and suprastanger uh.. im using your photo :biglaugh::biglaugh:
they should both fit but i know a lot of people get confused so maybe this will calm down pm's lol
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Ok, Im confused now. Im looking to do a 2JZGTE swap into my 88 turbo r-154. Which pan will I need?
eman2289
Feb 23, 2007
618
Jersey
Ok, so I can use an oil pan from a USDM 2JZGTE? What About a 1jzgte? Im sorry, Im new to the JZ scene.
suprastanger507mgte
Hayward , Ca
Yes a usdm 2jzge or gte pan will work.
a 1JZgte pan from a Supra or Soarer will work as well. ( both should be rear sump)
2JZge pan from a Soarer/sc300 will work as well. ( will need the oil return drilled)
If you need a pan, Im selling a 2JZge one in my for sale ad.
tlo86
Jul 24, 2005
3,914
Colorado
yes and yes. (i am using a 1jz pan on my 2jz check out my build thread it might answer most other questions or pm's)
tlo86
Jul 24, 2005
3,914
Colorado
annoyingrob;934508 said:
1JZ and 2JZ pans are the same part numbers. You can use a 1JZ rear sump on a 2JZ no problem. This is what I do.
I have an extra rear-sump pan, but I don't want to ship it to jersey.
the upper or lower pan or both?
