2500 RPM Rev Problem
supra1008
1,179
Philadelphia
Figured out what it was....
There is one extra wire on the body harness that shouldn't be hooked up to the computer. I'm not sure what it goes to yet. I'm going to figure it out so this problem will be completely resolved. Just go throught the wires until you narrow it down to which one shouldn't be there.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
its the A/C wire im sure
the JDM shit is controlled seperately. if you hook up the A/C clutch wire like you would in a USDM car it can over heat the circuit bored.
its a brown wire
supra1008
1,179
Philadelphia
That's the one!! The brown wire... stupid brown :nono: :biglaugh:
its a brown wire
The Reaper
Jan 10, 2006
1,909
Florida
yup
Grip-Industries found this out. its the A/C clutch wire
i de-pinned mine cause all it does is cause a transistor to get mad hot and pop
supra1008
1,179
Philadelphia
transistor or capacitor? Cause if it's the capacitor... then we've also solved why these capacitors are blowing in the ecu's
The Reaper said:
yup
supra1008
1,179
Philadelphia
Don't? Mine isn't connected. If you find out let us know. I haven't gotten to accessories yet. I'm still trying to get it running properly without blowing up.
Nopaint said:
so what would you do to connect a/c?
