Suprapowaz!(2);1732525 said:
Is that a bumper car steering wheel? I like those brake cooling ducts. Are you going to going to be filming this event? I'd like to see some video footage. Is it going to air on speedvision?
That is not a "bumper car" steering wheel. It's a circle track wheel with an oversized pad. I take the safety of my drivers seriously in my race cars. This car probably cost about $1500 more than it had to on safety equipment because I will not scrimp on that. No, it's not super fast, but I have no doubt based on what I saw on the in car video it will run north of 135 mph and half that speed is enough to kill an unprotected driver.
Back to the Diary. Saturday, Race Day!!
We go out and start circulating with all the other cars. We do have one of the better looking beaters out there and it seems strong. Our test driver, Mark, was the first one in. The loose plan was to run for 2 hours, until he got tired, or was low on fuel whichever came first. Since Mark was driving with two broken ribs I had a talk with him about not being shy about telling me on the radio if they were bothering him. We didn't really expect to do well at this race with a new car anyway and it's supposed to be fun, not a pain in the ribs.
At the end of the first hour we were running 9th, one lap down, with a best time of 2:28 and change as opposed to the leader's best time of 2:24 and change. Mark told me on the radio that the car was trying to run warm, up to about 220-225, if he started to push it at all. Oil pressure was 65 psi and we were making a little over 11 psi boost on the back straight. Because of the temp issues he couldn't really push the car as hard as it was capable of running. Midway through the second hour we decided to pit for fuel and driver change. Our second driver, Sam, was ready and the car came in.
Following is a rant that I'm still not over. In all of the previous Lemons races after the first one, we used a fuel cart I built. This is a 40 gallon cart with an electric pump and an auto shut-off nozzle. We could put 15 gallons in the car in less than a minute and a half and not spill a drop. This year they made a rule change where all fueling had to be done out of 5 gallon plastic jugs and a funnel. Naturally this caused huge fuel spills up and down the line of pitted cars everywhere (which is why I built the cart in the first place, to keep from spilling fuel). I protested the rule change when they made it and again, loudly, at this race asking Judge Phil in particular if he really #$#$@# thought this was safer than with my cart!?!?!? OK, rant over, back to the race.
After fueling my son Chris was helping getting Sam belted in and it was taking forever. In fact, we had a
13 MINUTE fuel stop and driver change. That wouldn't happen again, we weren't ready for the way they were doing it this year and it was different from last year, but what's done is done. Additionally as Sam pulled out I noticed we'd dropped about 1/2 gallon of coolant at our pit stall while the car was sitting out the overflow.
After a few laps Sam was having real problems keeping the temperatures under control and eventually, rather than fry a new engine, I decided to call him in for a radiator change and check the car over. Oh well, we didn't expect to win anyway. Sam came in and everything took longer than we wanted dealing with a hot engine/car to change radiators in.
At the end of the second hour we had dropped to 12th with a best time of 2:27 and change and 5 laps down.
Sam called in during the third hour and said the temps started OK but were climbing again and wanted to know at what point I wanted him to bring it in. I told him if he couldn't keep it under 225-230 come in so we can see what's going on. 5 laps later he had to come in.
We immediately noticed that the water pump was leaking out the weep hole. Now this was a NEW water pump when the engine went together. I did bring a spare used one so we got the water pump swapped out and sent him back out. For awhile, all was good, then Sam called in and said he was getting coolant on the windshield. I told him to pit now.
At some point, probably at the radiator change, we moved the lower radiator hose into a position where it was rubbing on the power steering pulley. It wore a hole in the hose and that's where the coolant on the windshield was coming from. I had another hose so we got it swapped out and put Doug in the car because Sam was also complaining of lack of power on the straights now and a miss. By this time we were at the end of the 4th hour and we'd fallen to 22 place about 16 laps down from the leader.
I wanted Doug in the car because he is a mechanic with his own shop just like I am and felt we could talk on the radio and communicate better what was going on with the car. The first few laps he felt the car was running well, almost 12 psi boost and able to pass anything on the track on the straights. Within about 5 laps the miss was back but in our diagnosing it we decided it wasn't really a miss, but rather a fuel delivery problem. Now when I built the car the tank was full of rust and varnish. I used muriatic acid several times to clean it out but was never really happy with it. I was afraid to go much further, though, as I didn't want a leaky tank. I've been there before on our other Lemons cars.
I called Doug in and we got the car on stands and changed fuel filters. I have the burns on my arms to remind me that race cars just off the track are freaking HOT.
That took almost 25 minutes and Doug went back out to see if things had improved. (BTW, the filter was FULL of crap, mostly what appeared to be rust)
We had dropped to 27th and 25 laps down by this time and were just hoping to get a decent finish and a properly running car at this point. Doug called in and said the car was running great.....Until about 6 laps later when it was losing power again. I called him in again and we took the hose off the fuel pressure gauge, the inlet off the filter hose, and blew backwards through the line. More rust, crap, and general nastiness came out into our bucket. Back together and sent Chris out and the same scenario. Car would run great for about a half dozen laps and then lose power.
This cycle of blowing out the filter, running for several laps, coming in, rinse and repeat continued to the end of the day and by that time we were running 40th, 100 laps down, and a best time of 2:24 and change. While our pit stops and mechanical woes were killing us, the time of 2:24 was encouraging as only 5 cars were faster lap times and we had in no way pushed our car at all yet.
Night came and Mark and Chris took his Vette into Denver to find as many fuel filters as they could find and a few other odds and ends while we came up with a plan of attack.
John Stricker
Dogma Racing
