2015 Projects: completed or in progress
rodel
SoCal
May 19, 2005
2,266
SoCal
What have you guys completed so far in 2015? What are you guys actively laboring on and plan to complete in 2015?
Please feel free to share. Let's add some excitement by including pictures. Thanks!
It's a dedicated Autocross/Track car I'm building for the fun of it ;)
L98 Crate engine
Callies 4" Steel Crank
Clevite 77 bearings
LS9 Cam
980cc Bosch ev14 Injectors
2x 460 LPH Walbro pumps
E-85 Sensor
140a Alternator
Morel Tie Bar lifters
Manley CroMo Pushrods
Crane Dual springs
Carrilo Blower pistons
Scat rods ARP 2000 bolts
ARP Studs Top bottom and sides
Harrop Stealth Force 2300 blower
Baffled Sump
Moroso Hi Volume/flow pump
Moroso Accumulator
Canton remote filter Adaptor
Mocal T Stat
Aeroflow Coolers x3
IJ/Difillipo SS WiY Kit headers
IJ/Difillipo SS 3" twin system
3" Spiral Mufflers
Powerbond Damper
ATI Driveplate
B&M Deep Pan
Raptor 700 4L65E Trans
2700 Circle D Multiplate converter
B&M QuickSilver Shifter
Harrop TrueTrac Diff
Harrop Diff Cover
IJ/AWD system
T3 Torsen Centre Diff
Full VZ Braking system with ABS/TRAC
12" vented/slotted Front rotors
12.5" vented/slotted Rear Rotors
AP 4 Piston Front
AP 4 Piston Rear
Competition pads
PWR Radiator
Rear mounted Ancilliary Cooling systems
IJ Coilovers
Koni Yellow Inserts
Kings Springs
Nolathane Strut Tops
WhiteLine adjustable sway bars F/R
IJ/IRS rear suspension
19x8.5 wheels with 255/40-19 tires road
16x7.5 wheels with 225/65-16 tires offroad
IJ/ Sub Frames
AGI Rollcage
Velo Race Seats
Velo Harnesses
rodel
SoCal
May 19, 2005
2,266
SoCal
This build looks intense awesome, IJ. Why did you choose an economy grocery getter as a platform?
What's the livery gonna look like for the V8 Supercar racing?
What's the livery gonna look like?
Thanks!
Original "plan" was to pick up a dead NA Mk4 but people wanted stupid $$$ for them here, the "Lexcen" is a rebadged Holden Commodore Toyota put out so they'd have a BIG car to sell here, it's a 1994 model I picked this one up running driving for $400 :)
There's a lot of parts cheap/available here for these things but since I started I've gotten carried away (again) and just about everything is custom...
The Engine/Trans is a proven quantity I used it in my Tow car for a couple of years and it makes around 450AWKW so around the 600 Hp mark.
For the Livery I was thinking about the early Toyota rally scheme as it's easy to reproduce.
BJ91T
810
Baton Rouge LA
I have 4 projects of my own on top of the daily customer requests
03 evo 8
92 teal turbo hardtop (7M Daily ish driver)
91 foxbody notch
78 280z (1JZ)
DeMoN2318
572
Arizona
Just got a set of MT ET Streets 255/50-16
Clutch in progress
ACT Extreme Pressure Plate
ACT sprung 6 puck
DM Lightweight flywheel
Planned before SIV15:
New composite HG with ARP studs
Timing Belt
Water Pump
Replace Valve seals
Replace rack and pinion and lines
60-1 CT26
Boost Controller
New Tune for SIV
New Lip
Geez...there is so much once I write it down...
rodel
SoCal
May 19, 2005
2,266
SoCal
03 evo 8
91 foxbody notch
78 280z (1JZ)
rodel
SoCal
May 19, 2005
2,266
SoCal
Clutch in progress
ACT sprung 6 puck
Timing Belt
Water Pump
Replace Valve seals
60-1 CT26
Boost Controller
New Tune for SIV
New Lip
Looking forward to SIV!
If it's not in progress yet, it doesn't count for the thread. :naughty:
rodel
SoCal
May 19, 2005
2,266
SoCal
Down went the subframe today for a complete suspension overhaul. Should be completed before April.20150222_085516.jpg
