You have a lot of searching on this forum before you get to 400.
MkIIItech will help also.
Good luck.
Good luck.
lppro said:i probubley will end up just doing a 20 over.. and i do plan on an ugraded turbo (when i get some more money saved) and for fuel i plan on 680 injecters and a Walbro pump.. and a lexus afm.. the fuel system and afm will probubley be the next mod after i get the motor back in and brocken in.. do you guys know what kind of power the stock 5 speed will hold?
AF1JZ said:Just think about it....You can have all the shit in the world on your car, but if you are using the stock turbo that isn't effecient over 14psi, what's the point? Go get the CT26 upgrade then ask.
whenmunkysfly said:and a fuel controler too can't just run 680 injectors with a lex afm it only works with the 550's unless you get a controller.
lppro said:what do you mean by controler? i have a hks fuel cut defencer... i dont know much about it though it was in the car when i got it..
LMAO scoff you may but one of mine did last yearDoward said:What IATs? The plastic cage would melt off....
IJ. said:1mm/0.40" overbore will maybe make 1>2 hp difference (not enough to measure accurately on a dyno)
The CT is the bottle neck and won't let the motor make any more hp no matter how big it is.
Listen to Bishop he's actually done it.
2543arvin said:On drjonez' website, he claims "the skys the limit" with the R154, and that may be a bit sarcastic, but lots of supra owners are putting down numbers in the 6 and 700 range with R154. And with the mods you are mentioning, I dont think you should have anything to worry about, given that your tranny is in good condition to start.
Boost Lee said:Tony Ortiz put down 822rwhp and ran a 10.2 with a stock R154 transmission.
He's now pushing quite a bit more power (or getting there, anyways :icon_bigg )...so I'm unsure of what setup he's going with now to put it to the ground.
Also - For the original poster: You need to understand that tuning is everything. It's not as simple as having a big high compression V8, a bunch of modifications and throw it on a dyno crossing your fingers (it's never quite that easy, anyways); but a car with forced induction (let alone 20psi on a stock CT-26)........trust me, you'll be wanting to do some kind of tuning. :icon_wink
Jeff
