2 threds into one. what do you guys think? and spacers
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
666theboy;1056225 said:
I wouldn`t either. Whats wrong with 225/50/16?:love:
i had those and after a while with stock suspension, it got old and started to look worse each day. so thats why i went to 225 45 17s. it looks alot better. i was gonna go with 18's but the wheels didn't have that size. and i even know a guy on sf that has 19's. but they is why i went with 17's. it just looks better in my opinion.
batttz
English Lurker
Aug 28, 2007
23
Hampshire
I had my rear studs shear off because I never knew you should put spiggot rings on your hub if the centre of your new wheels is larger than stock, but it's not that hard to replace rear studs
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
yeah i'm thinking of either putting in longer studs or 10mm getting h&r drs spacers. i would like to get longer studs cause it a bit cheaper just for that, but i want to stay away from the bearing. it too expensive for me right now.
supraman7mgte
Shut up,bitch!!
Sunny California
Replacing the rear wheel studs are easy.
I have 3/4's on the rear and 1/2's on front.It kicks the wheels out nicely and gives it a better stance.
You will have to get the wheels aligned so the tires will wear properly.
Crypton2006
294
Phoenix Az
When i worked at Discout Tire we would not touch a car with spacers, if that tells you anything. you need to lower the car thougth. Right now it looks like you could be sponserd by Rancho..lol JK
