2 step
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
Good thread, I want to set up my 2-step soon - what is of more advantage, to lunch on higher rpm with less boost or on lower rpm with higher boost? My main concern is driveline stress (transmission). RPS 3200lb pressure plate and HPF full face disc here
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
drjonez said:
launch RPM totally depends on your setup + tires. try out different settings and see what works best.
if you're concerned about driveline stress, don't drag race.
Thanks for good advice drjonez, actually I was asking about launching on boost on manual tranny from lower than 5000-5500 rpm. Is it easier for transmission vs. dropping clutch from 5500rpm ? With RPS 6-puck disk I cracked tranny housing
P.S. Sorry for late reply, have been busy last 2 days
figgie
Twin Cities, Minnesot-ah
answer doesn't change
drjonez said:
launch RPM totally depends on your setup + tires. try out different settings (and different techniques) and see what works best
