Ok ive got an 87 NA supra and i have a couple questions. I just installed a prosport aftermarket oil pressure gauge and when i coldstart the car oil pressure goes to an unbelieveable 80psi at 1500 rpm, if i rev it during cold i can get the pressure above 90psi. after its all warmed up i know the idle pressure is around 7-10 psi but i havent checked higher rpm yet.
My other question is i bumped my speedometer needle when iwas working on the cluster and now the speedometer is off, i was wodnering if you guys knew of an rpm to speed chart i could use to re-align my speedometer. Thanks a lot!
