2 Rebuild questions (so far)
bob-monk
22
UK
Hi all,
I just got my engine back after a full rebuild, but it's so long since i removed everything from it, i've forgotten where it all bolts!
so far i have 2 questions,
(but i'll probably be adding more as i go.)
(and i'll only ask stuff i can't find by searching, obviously.)
1) i have a 1/8" spacer for the flywheel, but does it go between the crank and the flywheel, or just under the bolt heads? (cant find it on the TSRM)
2) next to the dipstick hole in the block, just under the engine mount, there's a threaded hole (can only be seen with the mount removed). What bolts in to it?
Thanks for any help you can give me
bob-monk
22
UK
no, it's a manual, R154.
the marks on it suggest it goes between the flywheel and crank, but i'd like confirmation.
it is a UK car, but i can't see there being a difference.
bob-monk
22
UK
I know, that's what's confusing me.
It's definately come from there, as it's the same drilling as the flywheel.
ie, it only goes on one way.
i'm wondering if the previous owner had it made, to allow for metal being milled off or something, because surely Toyota wouldn't leave it off their drawings?
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
I doubt it, But you never know, I don't remember seeing a spacer when I assembled my engine and Box earlier in the year. Btw Are you a member of the uk forum??
bob-monk
22
UK
Thanks, here's the pic, and one of the crank incase it didn't look stock.
bob-monk
22
UK
Kotu100: any pics of the plug? i think my machinist must have removed and lost it, or would anything do the job?
and martin, i used to be,
i'm just on here more for the maft-pro info.
tho i do keep meaning to re-join.
lowtaco
282
Under a damn Toyota
The spacer is only used on Autos, there is one in front of and behind the flexplate. If you look on the Toyota EPC it is in section 35-02 with the flexplate and converter
bob-monk
22
UK
So i guess i'll leave it off, and see if everything goes together ok.
i just can't guess why it was on there.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
WARNING: DO NOT use the flexplate screws with the flywheel even if they are long enough to thread in. The flywheel screws are longer and will not loosen themselves or cause damage to your crank. Also, only use Toyota genuine or ARP flywheel screws, people have had issues with old or generic screws backing out on them and causing all sorts of havoc
bob-monk
22
UK
thanks for the warning,
but are those flywheel, or flexplate screws in my picture?
all i know is that's where they came out of.
dragracer
GearHead
Oct 31, 2005
221
Churubusco
The spacer in your picture is a toyota spacer used on the autos.
Measure bolt lengths to be sure. Cannot tell from pictures. You definately do not want to use auto bolts. Since that spacer was put on there, was this a auto car originally? That would explain why someone put the spacer back not knowing. If so, they probably used the flexplate bolts which will NOT work.
Rich
