Hi all,
I just got my engine back after a full rebuild, but it's so long since i removed everything from it, i've forgotten where it all bolts!
so far i have 2 questions,
(but i'll probably be adding more as i go.)
(and i'll only ask stuff i can't find by searching, obviously.)
1) i have a 1/8" spacer for the flywheel, but does it go between the crank and the flywheel, or just under the bolt heads? (cant find it on the TSRM)
2) next to the dipstick hole in the block, just under the engine mount, there's a threaded hole (can only be seen with the mount removed). What bolts in to it?
Thanks for any help you can give me
