my first topic is about BVSV (Bimetallic Vacuum Switching Valve)
Do i need it since i dont have the EGR setup? also can i just remove it along with the charcoal canister, or do i need the canister along with the BVSV (Bimetallic Vacuum Switching Valve)?
The reason why i am asking is because i have read that this sensor is supposed to activate the charcoal canister then it leads to the
EGR when the engine gets hot. AND because i was thinking of removing the BVSV (Bimetallic Vacuum Switching Valve) and put a temp sensor for a gauge
My second topic is about dyno numbers.
I am curious on how much horsepower i will be able to make on nest tuesday when i take my 87 turbo supra to get dyno. if any one has a guess on how much power i will be making on a MUSTANG Dyno.
My Supra has HKS VPC, HKS FCD, Walbro fuel pump, rc 550 injectors along with a Mallory FPR, Greddy boost controller and 3 inch exhaust after the turbo elbow, AC delete, electrical fans upgrade and auto to 5 speed swap with a auction clutch(its a six puck) with a fidanza light weight flywheel.
I WANT TO HEAR YOUR OPINION ON HOW MUCH POWER I WILL MAKE ON THE DYNO, THANKS FOR ANY IDEAS.
