should i go ahead and just 2jz my mkiii and pull the 7mgte and mab build that jst for the hell of it or wat? and is this a good deal on a gtte? with all components needed and the harness and mab the ecu also?
a_sesshoumaru;1334549 said:if you have the cash go 2jz, buy i doubt you will spend 2200 dollars doing the swap, even if you do it.
USPturbo89;1334907 said:reason i put tt is because ima get a twin turbo model.
