Hi all this is my first post on here and after some searching im not really getting clear answers on my Questions. First off im swapping a 1jzgte out of a soarer in my 78 280z and will be running the auto until i get the funds to swap a 5 speed in it. Here's some of my questions....
1. Will a sc300 rear sump oil pan work on the 1j if i tap the turbo drain in it?
2. Will the sc300 2jz w58 transmisson work and if so which flywheel do i need to use?
3. Can i run the hydro fan setup or would i just be better off swapping it out? And do i just need the 2j front pump and pulley to do so?
thank you
thank you
