1jzgte Vs 2jz
1jzgtte Vs. 2jzge
  • Total voters
    27
  • Poll closed .
88TARGATOP
2jz Here I Come
Nov 21, 2005
81
HALLANDALE, FL
sup everyone,
i have blown my headgasket for the last time on the 7m......
i wanted to find out what i should do, 1jzgte, or the non turbo 2jz, and boost the 2jz later????? any and all information is helpful....i dont care about my grammer or lack of puncation, and spelling abilites.
my main concern what will be more reliabe for daily driving, weekend racing, and easy and cheap faster up grades!!!!
thanxs alot!!!!
( i have 2 days for the decision!!)
I want to go to a 1jz later myself, but I know their is no cheap and faster upgrades. It will probably cost me four or five thousand to do a swap with a five speed, and a headgasket can be fixed for a few hundred. I guess it's your choice to make. If you can afford it then I would go 1jz, but I would never go to a non turbo. Just my two cents worth. Good luck.
GotBoost?
I do
Nov 25, 2005
318
By My Computer
^^Agreed^^^. Properly replacing the HG on that 7m is a whole lot easier than swapping anything in there. Even easier, but more expensive would be to sell your car as is, and buying a 2jz car. Your call.
PD: BTW, what was your hg/ head bolt combo?
88TARGATOP
2jz Here I Come
Nov 21, 2005
81
HALLANDALE, FL
I HAVE BEEN THROUGH 3 HEADS, AND GASKET IN THE PAST 2 MONTHS!!!! ITS A 88 SUPRA, AND IM GETTING A DEAL, ON THE 2J, BUT I REALLY WANT BOOST, THE 1JZ IS COSTING ME MORE THEN THE 2JZ,... I WAS ALSO THINKIN RB25DETT, BUT, YEA RIGHT, LIKE I WOULD DRIVE A NISSAN!!!
SuprAng
Garage Queen VV
Apr 4, 2005
112
Toronto, ON
3uzfe with 1uz rods and twins. > m/jz
There are no advantages to a 1.5jz over a 2jz apparently.
anyways, shit happens, i hate to say you suck at working on the 7m. Or maybe its just bad luck? Either way you need to decide what you want regardless of engine problems. If youre going jz to escape the "inherint" probs of the 7m, youre in for a surprise.
1jz is weak on the street, best race motor. 2jz is a good balance, but 7m is the best for the street use. Unless you want 10000000 hp, which it seems everyone does in which case niether engine is "ideal"
aye mate
Hiatus over.
Maryland
88TARGATOP said:
I HAVE BEEN THROUGH 3 HEADS, AND GASKET IN THE PAST 2 MONTHS!!!!!!!
Then do the job right next time.
Out of the 2 choices you gave I would do 1jz cause its boosted and it came in the MKIII so fitting it in there will be easier and more power for your money.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Cost. A boosted 3 liter, and the ease of running it off 1zj electronics. That was my main point, but true it wont give you any more power over the 2jz.
MKIIINA
Destroyer of Turbos
Plano, TX
if you can get the 2jz for cheap go for it but be prepared for some wiring to say the least. the 1j is nice and since its already turbo makes a difference as with the 2jzNA you were looking at doesnt have the oil squirters and other parts that help with FI later down the road that you will need to add if you want to run higher boost pressures.
8,897
88TARGATOP said:
sup everyone,
I vote for fixing it right the first time.
Between the other two, bigger is better.
I
itr206
Guest
Would you care to prove that theory on the street?
