1jzgte to ma70
87supradude88
ct
so ive been searching for days now and some of the post with links are a dead end im just looking for someone to clear up some missing pieces to my puzzle the 1 jz harness has different plugs then the 7m harness under the glove compartment do i need to cut and splice the plugs from the 7m to match the plugs for the 1jz or do they fit. also the 1jz harness has more plugs then the 7m.. unless there is a post that clears up the conversion under the glove compartment im kinda lost if someone can clear up the confusion that would be great thanks
87 supra 7mgte w/r154 trying to swap in a 1jzgte
te72
Classifieds Moderator
6,603
WHYoming
Check through the stickie'd threads in this section, might find the info you are looking for. Wiring isn't my specialty or I'd be glad to help. Good luck!
yes you need to use the mA70 plugs on the 1jz harness. also need to use the c1 connector.
