1jzgte swap
JStoked
646
Edmond, Oklahoma, United States
Ok im not new here but I haven't posted in awhile so here we go. So here is my set up that will lead to my question. I'm going to be doing a 1j swap into my 91 ma70. The set up is stock twins, usdm 2jzgt ecu, usdm 2jzgte 550 injectiors, afpr and fuel lines. So all that said. Can I use my 7mgte fuel resistor wired into the 2jz ecu. Will it pin out and work?
Anything will help thanks guys.
JonoTurbo
Going for broke
CT
I personally don't recommend it, I have heard from others that it works though. The resistance values are too far off of the factory ones to be safe on a 2jz ECU IMHO. Your best bet is to go with the acura legend box, which has 6 resistors in it instead of 3.
