1jzgte speed cut
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
You need to make a patch harness and add a few more wires.. It goes from batch injection to sequential injection, and also will allow you to run up to a 680CC injector (if you follow the rule of 1.5 x stock injector size) with a piggy back. It unfortunately drops the rev limit to 6800.
130ish MPH would be useful for a highway pull (in mexico) or if I was planning on trapping around there in the 1/4.
Well thats not bad. Ive never really seen people have problems with them. Then again ive never looked for it. 1jz ecus are horrible for that tho.
bioskyline
1,236
powell river bc
hvyman;1742098 said:
HAha. The wind gets crazy at anything past 120 or so.
that it does. on top gear(uk) when they did the speed test in the new veyron, at 450km/h+, the air is like driving thru a fuitcake, and the car need an extra 220 hp just to got a few MPH faster
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I went through a 2 in under 5k miles. Decided to make the switch.
Damn. ive gotten lucky so far. But i dont think my engine has had very many miles. Maybe like 20k. It was unbelievably clean and everything works flawless.
te72
Classifieds Moderator
6,616
9
WHYoming
chris_2jz;1742438 said:
132mph in 3rd? dude I'm scared to do 100 in 4th gear for the fear of damaging something. You can put an aristo ecu on a 1jz? What kinda benefit are there?
Really? Shit, I think I'd pretty much run the 1/4 in third with my current setup, all I'd need is the ability to rev a couple hundred more. I think I'm pulling ~102 or so in third at 7200. 100 in 4th, that's just... where you START fourth. ;)
chris_2jz
141
tampa
I can tell I'm babeing the hell outta my car then, I usually shift at 5-5500rpm in 3rd when pushing it.... I gotta man the fuck up lol
Sent from my Galaxy S phone
te72
6,616
9
WHYoming
No worries man, with a 7m, I'd probably try to keep the revs below 6k if I could help myself. 1j does just fine at higher speeds though, and behaves a little better up there anyway. :)
CRsupraiii
195
Cedar Rapids, IA
^it would be advisable to get a wideband instead of FCD; if you don't have one yet! Speaking of anyone have a good way to use this newly unlocked speed threshold without going standalone? From what I see Emanage Ultimate looks amazing.... I believe it can take care of speed cut too..
- Joe
Sent from my iPhone
kneedragger85
363
Boulder, CO
ma70suprawoner;1781474 said:
ive had my 1jz at 102mph but i hit fuel cut im pushing 12lbs of boost but i have my old 7mgte fuel pump and 370cc injectors i think my next move is a fuel cut defender and a speed cut limiter
Boost/fuel cut has nothing to do with your fuel pump or injectors.
