1jz wont start
heyguys i did my wiring last weekend and finished it up topped of all the fluids started right up i installed the driveshaft and touched nothing in the engine bay and now it wont start. it was running perfectly for 45min what could go wrong?
i checked the first coil pack no spark. im thinking ecu?:1zhelp: :1zhelp: :1zhelp: :1zhelp:
BigPants
Tucson, AZ
do you have an safc? my safc lost connection for no reason causing my car to not start. i had to go through and look at everywire untill i found one that maybe had a bad connection and resodered it. then she fired right up! good luck and if its wiring be patient because it IS frustrating.:3d_frown:
Spaniard
524
La pearla PR
yeah check your fuses. might be injector drivers or some caps in the ecu. if you have a buddy with a 1jz, ask him to let you borrow his ecu to see if it starts.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Double check the wiring in the engine bay to make sure nothing came loose. If you don't have it running after next weekend (going to hawaii this week), I might be able to come there. What's your zip code so I can see what kinda drive it is.
