1JZ wont go above 2000 RPM
GN_Convert
69
Florida
OK, I checked my crank sensor and the cam sensors using my meter and oscilloscope, with the troubleshooting steps from the 2JZ FSM engine troubleshooting section. All check out OK. Anything else I can check out before I drop the money to replace the ECU? I am looking at getting the AEM ECU from driftmotion, but would like to exhaust all other possibilities before spending 1300 bucks.
Thanks for the tips
GN_Convert
69
Florida
RickD;1889592 said:
Hey just wondering if you had any luck with this issue? As I am having a similar one on my supra...
I got an AEM ECU in it now, and it runs like a champ. If you have not had your capacitors replaced yet, I would go that route first. Driftmotion will do them pretty cheap if you don't feel comfortable soldering them in yourself
