1jz water pump bypass pipe part # ? or places to buy ?
Satan
Tampa
Do U mean the pipe that wraps around the block? I have a spare from a 2JZ, if you think it'd work.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
you can actually go to them without the part number and get the item its the same as a 2jz one
IBoughtASupra
4,455
Queens, NY
Jordan, check JZ thread. I have a section for reference to interchangeable parts. Tried as tested
1JZ pipe and 2JZ pipe are not the same. I should have a 1JZ one, I will check and see.
Maybe I should have some made up.
Radial
252
Norway
Turbo Habanero;1871873 said:
Thankyou Radial
So i can just go into Toyota and order these by part number correct
Correct. OEM toyota-numbers.
All Toyotas are on that website, just "add" your own car to the list.
Local toyota-dealers only get access to national sold cars...so a JDM spare parts catalogue is not available to them... you need to find the p/n yourself and they will get it for you within days. (usually 3-4 days in europe)
Radial
252
Norway
It is a valid part number, Toyodiy is a direct copy from toyota drawings. It's probably just an expired part number... toyota just need to find the new number. My local dealer finds out things like that in just a click.... but the JDM exploded view for any specific JDM car/Engine, he can not access through the toyota system.
