1jz VVTi shared parts
ganesht
Pupil
Jan 30, 2010
27
sd,CA
first thing, both the normal and vvti 1jz use the same connecting rods!
jzx100 pn = jza70 pn = 13201‑46030
Timing Belt - shared - 13568-49025
bobiseverywhere;378178 said:
The 1988+ Isuzu Trooper 4 cylinder 2.6 liter engine (4ZEL) uses the same belt as the Toyota 1JZ engine. So instead of getting a belt from Japan (~$100) you can pick up an Isuzu Trooper belt locally at an auto parts store for about $30 US. Make Sure You Get The 4 Cylinder 2.6 Litre Engine Belt!
timing belt specs: 137 teeth, 25mm wide
timing belt idler - shared - 13505-46020
timing belt tensioner - shared - 13540-46030
camshaft seals - NOT shared - intake: 90311‑40020 exhaust: 90311‑38056
serpentine belt - NOT shared - 90916-02308
intake Valve stem seals - shared -90913‑02090
exhaust VSS - shared - 90913‑02089
coil packs - NOT shared - 90919‑02216
afm - 22250‑50060
Pernilongo;1388404 said:
By the way, MKIV MAF from a TT engine also works, i use on my engine.
ignitor - 89621‑30020
soapra;1199713 said:
igniter is the same as any 2jzge vvti.
oil pump - shared - 15100‑46030
oil filter - shared - 90915‑20001
front crank seal - shared - 90311‑46001
rear crank seal - shared - 90311‑90006
crankshaft - shared - 13401‑46010
thermostat - shared - 90916‑03093
block - NOT shared - 11401‑49657
head gasket - NOT shared - 11115‑88410
**i could have sworn the hks mls hg listed the same pn for both normal and vvti
If you guys find any mistakes or updates, please tell me and ill update the post..
ganesht
Pupil
Jan 30, 2010
27
sd,CA
one part im not sure if shared is the oil pans.
iirc all vvti 1jz's are front sump, if someone needed to swap to a rear sump im not sure if they can use the normal 1jz/2jz rear sump
Grimsta
1,081
Santa Rosa, Ca.
how about the pans, vvtis are front sump. Use the regular 1JZ oil pan right? I just want to verify it will fit on the vvti 1JZ
