1jz swap
OneJArpus
2,798
wow, would have never thought i'd see you post here or that post.... but then again i barely know ya! lol.
Big Single > Small Twins
Big Twins > Big Single :)
Just my opinion tho. No real time # to prove anything on my end.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
lawlz nate if yuo can run like 11's on stock twins i hurd from my boi wif a 500 shot of NaWzzzz on his CRX. hes down wif all that 1JZ-GTTE JDM shyte.
ill help with the swap fo realz like. we can drink cheap 40's and roll mad baller style on wal mart hubcaps n shyte dawg.
i was plannin on 3 T88's fo my set up since they was so badass i thought i would make like 2000 hp if i had 3 yo
:rofl:
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
:rofl:
ok? Anyone else?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
response from the twins is amazing.....I don't think I have driven a turbo car with that fast of spool .But i don't think the stock twins will get you in the 12's
A single turbo will definitely get you in the 12s or lower depending.....
either you are joking about this or being serious...thought i'd share regardless..
aphxero
787
Seattle, WA
12 sec with 1j is totally possible with a lighter chassis.
2800lb cressida > 3400 lb supra
Only kidding guys. After all this is your house :)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I have some knowlegde of the 1jz from a tv show I saw one time where they were drifting. The only way the 1jz swap can be done is if you go to Japan and pay for your clip in cash and ride back with it on the boat. Bring back any parts you may need from Japan because 1jz parts are impossible to get in the US. The 1jz engine will only work if you have negative offset wheels with stretched tires. You also will not have enough room for an oil cooler, so it must be installed on outside of the front bumper. The 1jz only runs on leaded fuel. The 1jz has very little torque, but you can buy extra torque in Japan and bring it back with you. The 1jz hydrofan hose will work as air conditioning hose or a fuel line, and I have proof. Throw the hydrofan away and buy a electric fan, because the 1jz actually makes more power when it is overheating slightly all the time. The electric fan is magical and takes no power to run, while the hydrofan will suck almost 100 horsepower and make your car slow because it will be too cold.
That is most of the best tips I have.
OneJoeZee
Retired Post Whore
aboard the Argama
:rofl::rofl::rofl:
lol aaron. you are EEEEEEEEEEEEEVIL!!!
kwnate
Lurker
Jul 10, 2005
2,725
Finally a serious response... thanks aaron.
suprastanger507mgte
Hayward , Ca
That was a good show too. They also mentioned that 1jz was specifically designed to only run on 95 Octane. So if you are in Cali....you will also have to factor in the cost of moving to another state with higher Ocate :)
I guess this is what I have to look forward too, cause I am going to do a 1jz swap. I'm pretty sure my engine is trying to quit on me, and have been wanting to do the swap................lol
