I'm finishing up the wiring for the body plugs in my 89 ma70 and I'm down to 4 wires that I'm pretty sure are for the TEMS
From the ma70 B1 plug:
#2 (red with white stripe)
#3 (red)
#4 (black)
#14 (purple)
Now here is why I am a little unsure.. all of the body plugs had been cut already from the 1j engine harness, which makes it just a little more difficult to identify the wires. Also, I am unsure if all the wiring harnesses come equipped with TEMS wiring..
Anyways,
There is one red wire with a white stripe on the engine harness unused that leads into one of the ecu plugs
There is one solid red wire that also leads into the same ecu plug
There are TWO black wires available, one that leads into the same ecu plug as the other red wires, and the other going into the body of the rest of the engine harness (also, one black wire has two gray dots on it, whereas the other has only one gray dot)
There is one solid purple wire unused that goes into the body of the rest of the engine harness
So, is it safe to assume that the wires that go into that ecu plug are the wires I need to splice into my ma70 B1 body plug??
And is it also safe to assume that the last purple wire is also for the TEMS? According to a diagram I saw, it looks as if there should be TWO purple wires, one unused and the other goes to TEMS.. but I only have one anyways
#3 (red)
#4 (black)
#14 (purple)
Anyways,
