Hi guys,
I'm finishing up a 1jz swap into a sc300. Anyways, about a week ago I finished. Went to try and start it nothing. Turns out no spark and no fuel.
Since then Ive tried 2 different ECU. I checked the crank sensor and cam sensors which were all good. I'm getting voltage to the igniter and to the ecu. I'm getting voltage to the coil pack wires and the coil pack are in good condition and have good resistance.
I tested the igniter today on a friend car, it fired right up. So igniter is fine.
I'm thinking its a wiring problems. I've also added more grounds still no spark.
Also about the knock sensor with using a USB cable which one was that exactly? Also that wouldn't matter for starting would it?
I'm not getting voltage at the ign wire on the ecu when the key is on the 2nd on position. Anyone know if I am suppose to get voltage there when the key is on?
