Kosh said:Good news!!! THEY"RE BACK ON!!!! lmao, i don't really know if thats a good thing or not but we'll see i guess...haha anyways once i get her back running i'm going to start a build thread with pictures and everything i've done so far!
BTW I wish someone would have told me that if you remove the pins from the turbos then life becomes way easier to mount em back on the manifolds, and vice versa!!
Pins? You mean taking the studs out? Dude, I told you that!!
OneJoeZee said:On that note, when putting them back on, it will help you to take the studs out of the rear turbo flange. With the studs in, getting the assembly mounted on the manifold flange can be a real bitch. The rear intake pipe will hit the firewall or whatever else is behind it before you can line up the holes. But with the studs out, you can get the holes lined up pretty easy. Then you have to be able to hold it there and thread 1 or 2 studs back in. This is where a friend really comes in handy. Doing it by yourself will make your arms tired real fast.
HTH
