Hey all,
I know this is a crappy topic and everyone hates it. I do realize that this has been kinda covered in a few other threads but what i'm looking for is more specific answers to more specific questions. One thing i really wish this site had is a Sticky for a guide to stock twin removal. Here's the scoop, I recently bought a a new supra. Its a 1987 shell with a 1jz swap already done. The guy sold it cause the turbo's were done and i figured "what the hell, how hard can it be to put new turbos on"......Anyways you know how that goes.
So last night i started the whole thing. I got all the intake pipes off (except for that rear one), drain my rad fluid, disconnected all vacuum hoses and coolant lines, and then proceeded to undo all the manifold and y pipe bolts. I got the 3 manifold bolts off the forward turbo and the top one off the rear. I also got the 4 y-pipe bolts off the front turbo and then 3 off the rear. I can't get the one that hidden near the underside and closest to the block. I got it cracked but can't turn anymore then that due to lack of space between the bolt and the block.
Now i have not gotten the last 2 bolts off the rear turbo/manifold yet(the ones on the underside) because i figured that once i get the front turbo and y-pipe off those 2 will be easy, but now its looking like i'll have to get those 2 off to get the front turbo off. Also as a side note, i unbolted the front turbo from its mount but the left the mount connected to the block. I haven't touched the rear turbo's mount yet. I will take these off first when i get home tonight.
So where i'm at now is the front turbo is completely free of bolts except for the oil tube underneath. The y-pipe is loose except for that 1 PITA nut. And the rear is just free of tubbing and whatnot.
Where do i go from here, how do i get the first turbo off and then the second. Basically what i'm trying to start here is a step by step guide to the quickest and easiest route to gettin these puppies off. Everyone's input is much appreciated. Thanks.
BTW if anything i've said here doesn't make sense, please let me know and i'll correct it.
