1jz Starting/Dying Issue
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
Okay so the car's been down for a few days now, but this weekend, I will finally have the time to look at the car. And I know that I can easily search for similar threads or look in the stickies but I want more detailed and updated replies by everyone.
So here's the problem:About a couple of weeks ago, my car CEL started flashing and putting the car into limp mode. Sometimes it will limp for a few seconds and jump back into normal mode and sometimes it actually shuts off the engine. It got worst from there quickly. As time went by,it just got to the point where the car just keeps dying now. The CEL does not come on anymore. The car just dies,usually when I am in neutral or when I'm not on the gas. Now the car is very hesitant to start but it actually does once in a while. I actually got to start it the other day, but it died on me after I drove the car 10 yards. So the car cranks/chokes but there is no spark a lot of the times. But like I said, once in a while,it actually starts. So before I get to working on the car, I need to know every single thing that can be the problem. I want to know anything and everything that you guys think so I can list all the possible problems and eliminate them to find out what the real problem is. And sorry about being so noob. I don't believe it could be the ignitor,because if it was,then my car wouldn't be able to start at all right. It either works or doesn't work right? I don't have any leaks,MAP is fine and connected,idle is right. Do you guys think it could be spark,fuel pump,fuel pump relay,idle solenoid,iat? What do you guys think? I need HELP now. Thanks guys.
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
I am going to say that your ecu has taken the dive. Best bet is to open up the ecu and check for leaky capacitors. Old ecu's = old electronics that wear out and need replacing. Driftmotion does capacitor repair btw.
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
I opened up the ECU and didn't notice anything wrong. Everything looked fine besides that it smelled kind of rotten. How can I tell if something is messed up.
apexi287
401
Knoxville, TN
Pull codes you'll still have stored codes even if the light is off, that will give you a start on things. It could be a multitude of things, and as for the ecu caps they aren't always extremely bad and noticeable, mine were bad and there was such minimal leakage it was barely seen, but even just a little will screw with the ecu.
