ok, had a problem with wiring and ended having a power melt to a gnd and f some stuff up. i've gone through the harness and replaced all damaged wires...i've spent weeks trouble shootin and finally came to my current situation.
How is the aristo ecu grounded?? my ground wires coming from the map, tps, and iat aren't being grounded. i found this out by checking out the signal wire coming from the tps and it was at 2.6v at closed throttle, i'd slowly open and voltage would do somethin like this 2.6-1.8-1.7-1.6-1.7-1.8-2.2-2.5. (going from closed to wide open). so i knew something was screwy. looked last night and saw it should be grounded when closed so i knew it's a ground problem. today i cut the ground wire and made my own chassis gnd and it fixed the signal...so of course i cut the grounds to map, tps, and iat and sent them to chassis...but then the car wouldnt start...the ecu needs to be wired into these wires to start the car....
my current theory is that maybe another ground isn't routed properly and my main ecm ground wire from the ecu isn't even connected to a ground..basically i'm wonderin how the main ecm ground is connected to ground..is there a different ground coming from the ecu that connects to the chassis which serves as the main ground?
this probobaly doesn't make any sense cause i've had so many different leads for a few weeks and this is my latest and pretty sure once i figure out this ground issue i'll have my car back. please help. thanks much
